Griotte10
Aug 17, 2016Aspirant
Extender WN3100RP connected to router but no Internet
Hello, I am trying to reinstall my WN3100RP Extender, as I've had to change my router. It connects to the router, devices connect to the extender but for some reason, none of them can access the ...
DarrenM
Aug 19, 2016Sr. NETGEAR Moderator
Hello griotte10
I would factory reset the extender to get rid of all the old setting in the extender and then they to setup the extender again.
DarrenM
Griotte10
Aug 25, 2016Aspirant
Hello,
Thanks for the suggestion but I already did that several times with no success.
Any other idea?
Thanks,
Griotte10
- DarrenMAug 26, 2016Sr. NETGEAR Moderator
Hello Griotte10
I would make sure the routers security is set to WPA2 and try to change the wireless channel.
DarrenM
