Stevenec
Mar 05, 2019Aspirant
Extender won't connect to internet
So I have had my extender about 10 months now and no real problems that I was aware of. I recently upgraded my router so went to update the information for it with the extender and have now run into...
Christian_R
Mar 07, 2019NETGEAR Employee Retired
Hello Stevenec,
Factory reset the extender by pressing on the small black button using a pin for 15+ seconds and join the NETGEAR_EXT wifi network. After you connect to it, browse to www.mywifiext.net and follow the setup instructions.
~Christian
- StevenecMar 07, 2019Aspirant
Hi Christian,
I tried what you said and still cannot conect to the internet. I have reset it numerous times and then when I try to conect it to my router it won't go through, when I look it up through my computer it connects but then states there is no internet access. I even hooked it up through ethernet and still got the same problem. Everytime I enter the web address to enter the extender it says I am not connected to my extender's wifi network...but I am so I just don't know waht else to do. I also tried doing it through my cellphone and the same issues. Any further advice because I'm still stuck?
Thanks- Christian_RMar 08, 2019NETGEAR Employee Retired
Hi Stevenec - Were you able to locate the "NETGEAR_EXT" network and connect to it using a wireless device?
~Christian
