Roboclock
Dec 21, 2018Aspirant
Extenders connected, but no internet
My Neighbor is letting me use his internet when I go south for 3 months. I run two cameras for security and some wifi outlets. I put an extender in his garage and It works, but the signal is weak and...
Roboclock
Dec 23, 2018Aspirant
To refresh I am using a neighbors internet to run security cameras while away from home . I dont have internet at the house, I use a hot spot which I take with me. I have two repeaters in series to cover the whole house. So as I continue to try to set this up I find I can get things working, one time I had a speed oif 15gbs tahts thru both repeaters, I was elated, But the next day i had no internet, went through set up several times and got things working okay agian. But.. next day no internet.
So it seems that things won't stay connected. It might be that I loose connection with the host from time to time and the extenders reconnect but the auto settings change, thus I loose connection down the line. I'm thinking I have to specifiy the different addresses in each repeater and noy have them change. Which fields are most criticle?
