dorr's avatar
dorr
Tutor
Jul 02, 2019
Extending 2G and 5G signals
Hello. Is there some way on NetGear's product page to filter extenders that include 5g? I currently have the N300, which only does 2.4 GHz, and I know that this model does not support 5g. I wish to purchase a new extender for a medium size home that includes 5G.
Thanks for any help.
  • plemans's avatar
    N300 isn't a model number but most of Netgears routers that are n300 are either older devices or very basic models without much range.
    also, extenders need a decent signal/speed to extend. You can buy a super expensive extender but its only going to be as good as the router you're connecting back to.
    I'd look at updating/upgrading your router and seeing how you do first.  You say medium sized home but medium means something different to each person. What actual size are you trying to cover?
    • Thanks for the quick reply. My home is roughly 1200 sq ft, raised bungalow.
      • plemans's avatar
        I would look at investing that $ you were going to use for an extender and buy a dual band router. You'll notice a speed improvement just by getting some devices off your current 2.4ghz and having the higher bandwidth the 5ghz offers. Plus you'll avoid the con's of an extender (lower throughput, higher latency, more wifi interference, etc).
        Just my 2 cents.
