67badfish's avatar
67badfish
extending both 2.4 and 5g at the same time ex7500
I setup my new ex7500 on my laptop everything went as it should. if I connect to the 5 g next work the 2.4 led goes out and the 5 g light turns blue , if i connect to the 2.4 the 2.4 led turns blue and the 5g light turns red. if i connect with an ipad or phone in 5g the light still stays red and the same if my laptop is connected to the 5 g and i connect a phone or ipad to the 2.4 the 2.4 led is still not lit.
  • plemans's avatar
    What firmware is on your extender?
    What router are you connected back to?
    have you looked at the manual for what the led's mean?
    • Solid blue. Best connection.
    • Solid amber. Good connection.
    • Solid red. Poor connection.
    • Off. No connection.
    Are you unable to connect to the 2.4ghz and 5ghz at the same time (from different devices)? A little better explaination of what the actual problem is will help.
    Here's where you can find firmware, manuals, troubleshooting info.
    https://www.netgear.com/support/product/EX7500.aspx
    • 67badfish's avatar
      67badfish
      I updated the the firmware to the current available . modem is a zyxel emg2926-q10a.
      • plemans's avatar
        but you didn't answer any of the other questions.
         A better explaination of the problem helps.
