emmetb
May 11, 2022Initiate
Extending wifi to two outbuildings
I am in the UK and have a BT broadband connection and Smarthub (wireless/Ethernet ports) that gives good speeds. I want to extend the wireless network from this hub to two outbuildings. In preparation for this I ran shielded Cat6 cable from the hub's location to the first outbuilding (10m away) and then a second shielded Cat6 cable from this outbuilding to the second outbuilding (40m away from the first).
I want to daisy chain wireless access repeaters on the end of these cables to provide wireless in both outbuildings and get good speed in both. What products do I need and how do I set them up?
Just so as you know wireless from the hub to the outbuilding will not work due to wall thickness hence why I ran the cables. I could have run cables from the hub to each outbuilding which may have been better (as could connect each extender directly to the hub in that scenario), but I didn't and can't do that now (as cables are buried) hence why I need to daisy chain them.
All help much appreciated.
yes you can daisy chain. Some of the satellites have more than 1 ethernet jack. You'd just go router------>satellite------>satellite with ethernet. If you happened to have a satellite with only 1 ethernet, a simple unmanaged switch would work
I wouldn't use extenders. I would just go with a mesh system. Netgears orbi line support a wired backhaul so you could put a router in the house and a satellite in each building. It'd be simpler than trying to rig up extenders to work and would be a lot more set and forget.
- emmetbInitiate
Thanks for the reply and that sounds like an option having done some reading up on your suggestion. What I am unsure about is how I would connect the devices. I'd need a 'parent' node in the house that would connect to the Smarthub and then two satellite nodes, one in the adjacent outbuilding and then another in the more distant outbuilding. I currently have a CAT6 cable between the two outbuildings in readiness for this and a Cat 6 cable from the adjacent outbuilding to the house. What I don't have (which would have been more sensible) is a cable from the furthest outbuilding to the house. So I sort of need to daisy chain the satellites... hub -> parent -> satellite 1 -> satellite 2 ... is that possible? Can I out some sort of 'splitter' in the first outbuilding to connect both satellites to the parent? Apologies if this is not making sense.
