Overboard
Dec 03, 2016Follower
Extending Xfinity Hotspot
I had a 6150 which had no problem passing the Xfinity logon page to devices. Worked well. But it decided to go overboard,so I got a 7300 figured it would work the same way. I cannot access the logon...
DarrenM
Dec 05, 2016Sr. NETGEAR Moderator
Hello overboard
You can try to go to www.mywifiext.net or if you are able to find the ip address of the extender in the routers page type that Ip into your browser and it should bring up the login for the extender.
DarrenM
