jtwill98
Nov 05, 2015Follower
External Antenna for AC1200 WiFi Range Extender
A couple of questions regarding external antennas for the AC1200 WiFi Range Extender. 1) I have a yagi 2.4 GHz antenna. Which external connector should I use, top or bottom? Does it matter? 2)...
nhann
Nov 17, 2015NETGEAR Employee Retired
Hi jtwill98,
Please note that replacing the EX6200 WiFi extender antennaes will void your warranty.
The following antenna may help: http://www.amazon.com/Super-Power-Supply%C2%AE-TL-WDN3800-TL-WN851ND/dp/B013T5TA44
Usually it is SMA type for the connector
