BobThomas
Oct 19, 2014Follower
External Antenna
Can i add a USB Antenna to the WN3500RP to get even better reach? I am using it in my RV which is essentially a metal framed box that keeps campground wi-fi from getting to our devices inside. Would...
storm_2003
Oct 20, 2014Novice
Hi BobThomas,
The USB port of WN3000RP is intended only for USB hard disks for ReadyShare access. It will not work on your USB Antenna.
If you need directional antenna try to look at business access points that has reverse SMA antenna connectors for external antennas but still not USB.
http://netgear.com/business/products/wireless/business-wireless/
