Urrno
Oct 16, 2018Aspirant
Extremely Slow Ethernet Connection Through Wifi Extender
I have my desktop hooked up to my wifi extender through an ethernet cable. Currently, my donwload speed is less than 1mbps. My phone, which is connected to wifi and is in the same room as the extende...
Oct 17, 2018Guru - Experienced User
Did you try restarting the extender?
Urrno
Oct 18, 2018Aspirant
Restarting the extender did not help much. My speed is up to 3 mbps, which is a little bit better, but not nearly as good as it should be.
- StephenBOct 19, 2018Guru - Experienced User
What speed do you see if you disconnect the PC lan cable, and connect the phone to the extender's network?
You might also use the Windows task manager (clicking on the performance tab) - just to double-check that there isn't a background task that is using network bandwidth.
- UrrnoOct 19, 2018Aspirant
Connecting to the extender with my phone is even worse. 0.7 mbps on phone through wifi, currently 3 mbps on desktop through ethernet.
Definitely nothing else hogging bandwidth, as I unplugged the connection to the desktop before testing on my phone.
What color is the router led on the extender?
Restarting the router is probably a good idea if you haven't tried that already.
