JohnDe
Apr 18, 2020Guide
Fast Lane - doesn't make sense
Can anyone explain the advantages of Fast Lane because it doesn't make any sense to me? Either way you set it it amounts to 2.4GHz - either it's 5GHz from the router> 2.4GHz to the devices or 2.4GHz from the router> 5GHz to the devices.
How can that improve performance over maintaining seperate 2.4/5GHz channels and connecting your 5GHz device to only the 5GHz channel?
the reason why is that when your a single radio (wireless chip/band) is having to receive and then retransmit dat, it cuts the bandwidth in half and increases latency. Reason why is it can't do both at the same time.
If you set 1 of the chips just for router--extender communication (fastlane) that chip isn't receiving and then turning around and rebroadcasting. Its able to pass it directly to the other band/chip in close to real time. the decreases the bandwidth and latency hit they take.
it still takes a little bit if one but its much less than standard extender mode.
Its also why the tri-band extenders work so well. they specifically setup with 1 of the 5ghz bands (higher throughput) for router----extender communication. and that enables the 2.4ghz and other 5ghz radio to communicate faster/lower latency.
- JohnDeGuide
Thanks very much - your explanation was much clearer than support, that totally misunderstood the exact same question. So just to be clear, Fast Lane will always produce a wider faster bandwidth than basic, regardless of 2.4GHz or 5GHz connection? If so, which one is quicker with both all devices and router dual band.
Many thanks.
- JohnDeGuide
I meant which Fast Lane Setting: Router>2.4GHz>Extender>5GHz>Devices, or the other way round.
