rlfisher's avatar
rlfisher
Follower
Apr 01, 2018
Firmware update - correct version
I received an email notification of a firmware update for my AC1200/EX6920 range extenders.  However, when I follow the download links, the release notes mention EX6120, but not the 6920.  Can I use this firmware update or do I need something different?  thank you
  • Hi rlfisher,
                        Package name is EX6920 whereas each unit's model will be EX6120 which you can see on extender itself. Yes, you can upgrade the firmware of EX6120.
1 Reply
  • Hi rlfisher,
