Bob5545's avatar
Bob5545
Firmware Update not found!
AC1900 WiFi Range Extender
  • Hardware Version: EX7000
  • Firmware Version: V1.0.1.104_1.0.184
New update is available. Click here to start
It never finds any update??????  Is this the most current update for this extender?????
If it is, how so I turn off the new update notification????
  • michaelkenward's avatar
    michaelkenward
    The on-board check is notoriously unreliable. The best way to check is on the support pages for your product.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Look for the model number on the label on the device.
    That page will also have any software, firmware and drivers for your device, if they exist.
    There have been two new version since yours.
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
    • Bob5545's avatar
      Bob5545
      Thanks I did that but it still was not clear what were newer firmware updates.
      There was no recommendations for updates to my current firmware.
      Do you have the firmware updates I need to make this older extender more current.
      Thanks
