Andre_Ventura
Dec 11, 2016Aspirant
Firmware update on a WN1000RT
I use a WN1000RP to extend the range of a hotspot network provided by a closeby neighbor, which uses a captive portal approach. After upgrading to the latest firmware release (1.0.0.52) that beca...
DarrenM
Dec 13, 2016Sr. NETGEAR Moderator
Hello Andre_Ventura
The home extenders are not meant to be used with these type of login pages you may have to look at a business extender for something like this.
DarrenM
- Andre_VenturaDec 19, 2016AspirantThat is not a proper answer. There no standard definition of home extender vs. business extender. If I had the problem in the beginning I would had return the equipment immediately; now I cannot do it anymore. So, the solution may either install a previous firmware, or to get a new one, without this limitation.
