Srgza's avatar
Srgza
Firmware update WN1000RP
Hi
I bought and successfully installed the range extender on my existing network. When I logged into the _EXT router, the first page that came up was an update page asking if I wanted to upgrade the firmware as an update was available. I clicked yes, and the router went thru the download and install. It then disappeared as a network and refused to reconnect. After an hour, I switched it off, removed it from the power, then restarted. I now get a constant amber light on the status LED and no visible network. I have tried the factory reset but no flashing amber light, it just stays on. Please help, as I have no idea how to correct this problem!
Many thanks!
