AdrianCr
May 17, 2018Guide
Firmware updated EX8000 keeps dropping Internet
Hi all,
I have read about multiple issued relating to the R8000 but I seem to be experiencing a similar issue with your EX8000 mesh range extender.I regularly experience an issue (perhaps once ...
DexterJB
Jul 22, 2018NETGEAR Moderator
Hi flyturbo,
Welcome to the community!
Once on the extender's UI and on the Firmware Update tab, there is an "Upload Update File" box where you can point the extracted firmware file of the EX8000 found on this link.
Dexter
Community Team
flyturbo
Jul 23, 2018Apprentice
DexterJB wrote:
Hi flyturbo,
Dexter
Community Team
Dexter, I was referring to downgrading the firmware and was not asking for "how to manually upload a firmware file".
In case you haven't caught on, I am having major issue with the extender, .do you have any solutions for me? Please do not ask me what issues am having because i have posted in this thread and 2 other ones.
Bruno
Unhappy netgear owner.
- AdrianCrJul 23, 2018Guide
Hi Bruno,
First download the old firmware and then follow Dexter's advice, pointing to the old firmware file.
Like I did, you can try to rule out possible causes
1. Conflict between wireless router and mesh router
Sindric's answer (previously) is probably the best to narrow down the problem i.e using the device as a wired extender. i.e connected by a ethernet cable to the router. If the fault persists then the issue must be with the extender. Just make sure you setup the wired extender with a static non conflicting address AND obviously turn off the wireless on your router!!!
2. Conflict between extender and device
I would also suggest connecting one PC like device to test at a time. There could be issues with the Network card in other devices that are causing the problem. Some Windows 10 devices can have a dynamic MAC addresses turned on. Suggest you disable that feature for now.
3. Conflict of bands - Turn just one band on at a time.
PS. I gave up and sent mine back. Like you I was upset with the lack of service and that there is no logs to even remotely point to a problem.
PPS. Almost 2 months to the day I received an email from support suggesting I call them. 2 Months. Wow.
Cheers,
Adrian
- flyturboJul 24, 2018Apprentice
This is the error I get when trying to downgrade the firmware to EX8000-V1.0.0.118.zip;
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
