AdrianCr
May 17, 2018Guide
Firmware updated EX8000 keeps dropping Internet
Hi all,
I have read about multiple issued relating to the R8000 but I seem to be experiencing a similar issue with your EX8000 mesh range extender.I regularly experience an issue (perhaps once ...
MightyAtom
Oct 02, 2018Guide
Hi all,
A bit new to all this but I also have an issue with the EX8000 dropping the internet to my wired devices.
I have three PCs wired to the EX8000 and this inturn is wirelessly connected to my Netgear R7000 Nighthawk. The R7000 has been really good but since connecting the EX8000 I have issues with my PCs dropping the internet, even though they are wired.
I saw a thread relating to setting a static IP address but not so sure how I would do this, on the R7000 or EX8000??
flyturbo
Oct 02, 2018Apprentice
I have had the same issues since day one. I downloaded the latest firmware on Sunday and surprisingly it’s holding up. Only time will tell.
The latest firmware isn’t available yet from the extender, you will have to download it from Netgear’s download page. Don’t forget to unzip the file, you need to upload the *.Img file.
good luck to you
- MightyAtomOct 04, 2018Guide
Hi Turbo,
Just updated to teh 180 firmware so lets see how it goes, thanks for letting me know that there was new firmware. I have also set teh EX8000 with a static IP (I figured out how to do it al on my ownsome!!).
Ok, just changed to the new firmware (180) and now the EX800 says no cnnection for my 5Ghz network but teh 5GHz light is on? any ideas do I have a 5g connection??
- flyturboOct 20, 2018Apprentice
I had same issue, do a cold rest using the reset button in back of the unit.
Unfortunately, the newest firmware still doesn't resolve connection issues.
