AdrianCr
May 17, 2018Guide
Firmware updated EX8000 keeps dropping Internet
Hi all,
I have read about multiple issued relating to the R8000 but I seem to be experiencing a similar issue with your EX8000 mesh range extender.I regularly experience an issue (perhaps once ...
Freebeard
Dec 18, 2018Guide
SOLVED
Okay, everyone. With the previous posts, I can confidently say (as of right now... days or even minutes into the future... we'll see) that I have solved the issue of the Mesh Extender suddenly dropping the 5GHz backhaul, causing all sorts of doubt and hatred toward Netgear (which I still hope they fix and or explain so that others with this problem can also solve it).
These are the things I did
1. Set the Mesh Extender IP Address to static on the http://mywifiext.net under the Settings>Wireless>IP Address>Use Static IP Address
2. Set the IP Address of the Mesh Extender to static on my R7000 under Advanced>Setup>LAN
3. On the Router control site, I changed the 2.4 GHz channel to 11, because according the my Netgear App, 11 was free. Go to Basic>Wireless and change the channel from Auto, to a number so it stops switching channels, causing the random 14 minute or so drop out of the 5GHz backhaul
4. Just for kicks and giggles, I also turned on QoS and maxed out my PC and the Mesh Extender with priority... probably not necessary at this point, but what the hey
5. I am now currently enjoying my insane internet speed from the tucked away basement office which once suffered from 20 percent connection of my actual router (because of the way they wired the internet into this house, I had no other option than to get a Mesh Extender)
Again, as said before on this thread... the 2.4 GHz channel set to Auto is the thing that is messing this all up. CHANGE IT!!!!!!!!!!!!
burneyfalls
Dec 19, 2018Star
I did everything you did except I put the 2.4Ghz backhaul on Ch 6. None of it worked. I was still within my 90 days warranty and Netgear RMA'd my unit for cash refund after much haggling. I am awaiting my refund.
My conclusion: The technology is flawed. It doesn't matter what company built it (NetGear, D-Link, Linksys, TP-Link, etc). They all use the same technology and it doesn't work over time. If you look at the reviews for the flagship extenders from any of these companies, they ALL have the same problems. I have gone back to my old D-Link wireless media bridge setup to satisfy my specific needs. I have just the router (ASUS RT-AC68U) in my house with no extenders now and that is good enough coverage to support 5 people and 200mbs DL from the cable company. I may try a cheap (<$30) extender in the spring for coverage into my backyard. I'll revisit the 2.4Ghz router coverage out there and avoid any extender if possible.
- FreebeardDec 19, 2018Guide
Sorry to hear that. My plan is to leave everything alone on the router and extender, and if I make any adjustments, I'll know there will be about a 14 minute drop out of the 5Ghz. Weird, makes no sense, but it shouldn't happen now unless I adjust my router settings/channels. If I discover anything else, or think of anything I've missed, I'll definitely share it here.
- burneyfallsDec 19, 2018Star
You will resolve the 14 min 5Ghz backhaul dropout if you put the 2.4Ghz on a fixed channel and you have done that. However, there will still be IP issues even with everything set up with static IPs. That is what I experienced.
- BaDCrCDec 19, 2018TutorDon t have any more dropouts for the last 4 weeks.
Fixed channels 2.4 and 5
Fixed IP
Disabled the "smart" option to have the same said for all the network. I am specifying now where to connect for each device.
