AdrianCr
May 17, 2018Guide
Firmware updated EX8000 keeps dropping Internet
Hi all,
I have read about multiple issued relating to the R8000 but I seem to be experiencing a similar issue with your EX8000 mesh range extender.I regularly experience an issue (perhaps once ...
Mar 25, 2019Guru - Experienced User
Some have reported that recent FW is not working right on the 8000. Others reported that revertting back to last working version helps. You don't always have to update FW. I have a friend who uses a EX8000. Zero issues. I'll see what version he has loaded.
- burneyfallsMar 25, 2019StarYeah, right, no issue. That's a bunch of baloney. They all have similar problems even across different manufacturers. Just buy a simple extender like the one I recommended above. It works great and fairly cheap.
