AdrianCr
May 17, 2018Guide
Firmware updated EX8000 keeps dropping Internet
Hi all,
I have read about multiple issued relating to the R8000 but I seem to be experiencing a similar issue with your EX8000 mesh range extender.I regularly experience an issue (perhaps once ...
bobby_digital
Jun 07, 2020Aspirant
Very frustrated with this device. I'm having the same issue as everyone else where I have to restart it about once a day in order to reconnect to the internet.
This was way too expensive for such poor quality. Going to return it and buy something else
- joker7380Jun 07, 2020AspirantI uninstalled the Netgear Genie from my computer and my dropped signal problem went away.
- johnsancJun 14, 2020Tutor
After struggling with this mesh extender for over a week I decided to pull out all the stops and try to figure out why internet kept dropping but my devices would say they were connected and appeared perfectly fine.
In short: The virtual MAC addresses the extender assigns are likely causing conflicts with your router's ARP table.
I decided to install pfSense on a micro-pc and use my RAX75 as an AP. The EX8000 acts as an extender for this AP. I noticed, like others have mentioned, that the wired connections work perfectly fine when the extender has WiFi connectivity issues. I also noticed that as soon as I unplug the extender my WiFi is fixed. I tried rolling back several firmware versions and I couldn't find a single one where this worked "properly". This alone really narrows it down.
I then did some digging around how the extender actually works, and its documented by Netgear that this extender (as well as many of their others) create virtual MAC addresses for the devices that are connected to it. So then what happens when I have an IP assigned to one device then the MAC address changes because I roamed to and from the extenders range? Answer: It chokes - Unless something tells the router that the device at that IP address is now at a different MAC address. Or rather
This extender apparently does a horrible job at letting the router / AP know when it links the virtual MAC address to the IP the device was using. My fix is crude, but so far seems to work. In pfSense I created a tunable for "net.link.ether.inet.max_age" to set the value to about a minute. This basically means the entries in the ARP table (IP address <---> MAC address) expire after a minute. This sort of feature will vary by router, any many may not allow any sort of control over this. I suspect the "14 minutes" referred to earlier in this post may actually be a common ARP table entry expiration value.
I may not be 100% correct in my assessment since I am not a networking guru, but I do know that as soon as I deleted the ARP table cached entry for my phone's real MAC address, the internet worked again. And so far my shortended cache seems to have fixed the issue across all devices (so far, knock on wood)
- johnsancJun 16, 2020Tutor
Well that only temporarily fixed the problem. No longer worth my time - returned it to Best Buy and never buying another Netgear product again.
Lost a customer due to overpriced hardware, buggy firmware, poor support, and in this case a product that is flawed so badly it cannot even perform the primary function it was meant for.
