TDawkins
Nov 04, 2018Aspirant
Front Flashing white, and power flashing red
For the past week, my extender stopped working. The front lights flash white and the power light in the back flashes red. Theres nothing in the manual about the issues im having.
RJG202
Feb 18, 2019Guide
mama2ewmm wrote:
I'm having this same issue. I've had it unplugged about a week or so until I could deal with it. I plugged it back in tonight, green power light came on briefly, then went back to flashing red with all front lights flashing white. I tried a week or so ago to reconnect but nothing happened. Tried resetting then and tonight, holding the reset button about 10 seconds and nothing changed with the flashing lights.
Did you ever get resolution? I have same issue.
HR00
Mar 16, 2019Aspirant
I’m having the same issues and can not find my manual. I have unplugged and reset many times with no luck
- FURRYe38Mar 18, 2019Guru - Experienced User
I would contact NG support about this:
https://www.netgear.com/mynetgear/registration/login.aspx
