tanto20
Aug 03, 2015Aspirant
Getting internet in my Garden office
I am looking to build an insulated timber built garden office. It'll be about 100ft from the house, and the router is probably another 20 foot from the back door. I'm on Virgin and get about 30mb dow...
tanto20
Aug 04, 2015Aspirant
Thanks. Okay it's getting very techincal now for me! no idea how to do this although I am not bothered about a printer. I don't even need that amazing a connection,I just need a consistent one. Can't seem to find out how far the range is on the wifi extenders as i'm hoping I can go that route
Shadowlore
Aug 13, 2015Guide
WiFi extenders ranges generally vary, based on if you use the default antennas on them, or if you get directional antennas. Right now, I have an extender going from my house, across the street, to a neighbor's house.. the distance is about 100-120 ft, and it works rather well... but it IS direct line of sight, too.
As mentioned above, if you have power running out to your office, you can use powerline/homeplug as an option.
HOWEVER, the one caveat is that you can NOT have multi phased power to your residence and office. As a rule of thumb, the most common way of knowing if you have 'multi phased' wiring, is to check the back of your house. MANY times, you'll have 2 meters if you're multi-phased (not always, but it's usually a good indication).
Basically, what the technology does, is convert your ethernet (network) cable so that it can use the power outlets in your home, to transmit and receive data. It's generally not as fast as straight ethernet, but it's supposed to work well enough. (Note: I've not used homeplug/powerline tech in a few years, but I'm due to do a deployment in a few weeks, so I can check in and give you more info at that point, if you'd like :)
- tanto20Sep 02, 2015Aspirant
Had an electrician round to cost up the job, because I already have an outside electrical cable running underground to my current sheds, so his job will be to kit out the garden office and connect the cable to the house. He said it would go right into my fuse board and wouldn't technically be running off the same cabling as the house wiring but the cables are linked together so powerline adapters MAY work. No guarantee though so I think I need a plan B option to somehow boost my wifi down there. Is it possible to get some sort of booster to plug in by the back door of my house, that will reach 100ft away to the office? or piggypack it to another booster in my office? I don't really want to run cabling down my garden and I have seen some of those units that fit outside but are powered by ethernet - the only problem with that is I won't be able to use other devices down in my office at the same time.
- nhannSep 02, 2015NETGEAR Employee Retired
An option is to connect Extender #1 to the back door of your house and set this up with an ethernet to run as 'Access Point'.
Then connect Extender #2 in your office and run it as 'Extender' and connect to #1.
Please note that if you set up #1 to run as wireless 'Extender' and #2 connecting to #1 via WiFi, then it would not work. (Daisy-Chaining)
http://kb.netgear.com/app/answers/detail/a_id/24801/~/what-is-a-wireless-extender%3F
