oodee
Dec 17, 2018Follower
getting wifi in a metal shed
I have my workshop in a metal shed. it has a big roll up door but no windows. when the door is open i get a reasonable signal (2 out of 4 lines) that allows me to wathch tutorials etc. however, when ...
Dec 18, 2018Guru - Experienced User
Netgear extenders with external antennas have 2-3 on them. It might be possible to replace the antennas on the larger desktop models yourself, but any damage would undoubtedly void the warranty.
If the shed is getting power from the house circuit box, then I suggest going with powerline networking instead (for instance the PLW1000). You'd connect one module near your router, and connect to that with ethernet. The WiFi module would plug into a socket in the shed, and would provide wifi there.
