mone5898
Aug 10, 2014Follower
Good connection - Poor speed
So I have the EX6200 setup in a granny flat and it was giving me 25-35 Mbps speeds. Suddenly there was a drop in speed to around 2 Mbps. After talking to telstra and making sure my gateway was fine I ...
storm_2003
Aug 12, 2014Novice
Something in your network environment that is causing the speed drop as you mentioned 35+ speeds when you move it closer to the router.
Recommendation:
- remove any wireless device that might interfere in between the router and the extender
- place the extender where you still get strong signal from the router (test this using your laptop)
- try changing the channel use inSSIDer to set the right channel for your network.
http://www.inssider.com/downloads/
Recommendation:
