CCBaxter
May 21, 2017Aspirant
Half speed even with Fastlane?
Hi. I have a 6150v2 range extender, configured to use Fastlane. It connects with my router using 2.4GHz (wireless N) and with my devices using 5GHz (wireless AC). When I'm connected directly to t...
DarrenM
May 25, 2017Sr. NETGEAR Moderator
Hello CCBaxter
Have you tried to change the wireless channel to see if you get a faster connection?
DarrenM
CCBaxter
May 27, 2017Aspirant
Hi, thanks for the reply.
Haven't tried that yet, will try it later today.
About Fastlane, do you use it? Do you have the same speed as when connected directly to the main router?
- netwrksMay 27, 2017Master
Using an extender will give you a 50% loss in throughput. So, 35Mbps, is about right.
EDIT: your extender supports AP mode, you should strive to set it up in AP mode.
- CCBaxterMay 27, 2017Aspirant
Even when using Fastlane? I thought the whole purpose of using it was to avoid the 50% loss in throughput. What's the advantage then? Stability of the connection or something like that?
To set it up in AP mode I need a wired connection to it, right?
Fast lane has nothing to do with how extenders work.. It allows you to select is to be your uplink - 2.4ghz or 5ghz. You can always try swapping your fastlane uplink, to see if that improves your throughput. Looke like there are 3 options for Fastlane.
Yes, you would need a wired connection. If running Ethernet is a hassle, have a look at powerline to set up a LAN connection from an AP to a Base router. Look for AV2 powerline.
RE: Fastlink link: https://kb.netgear.com/24662/What-is-FastLane-Technology-and-how-do-I-configure-it
