CCBaxter
May 21, 2017Aspirant
Half speed even with Fastlane?
Hi. I have a 6150v2 range extender, configured to use Fastlane. It connects with my router using 2.4GHz (wireless N) and with my devices using 5GHz (wireless AC). When I'm connected directly to t...
DarrenM
May 25, 2017Sr. NETGEAR Moderator
Hello CCBaxter
Have you tried to change the wireless channel to see if you get a faster connection?
DarrenM
CCBaxter
May 29, 2017Aspirant
Tried changing channels, I get the same results.
Phone directly connected to the router - 80Mbps
Phone connected to extender - 35Mbps
This isn't bad at all, and 35Mbps is enough for the streaming I do in the room that had poor wifi.
I'm just wondering if anyone here knows exactly what are the benefits of using FastLane and clarify if people should expect better speed when using it, or the usual 50% loss that's common in range extenders.
