CCBaxter
May 21, 2017Aspirant
Half speed even with Fastlane?
Hi. I have a 6150v2 range extender, configured to use Fastlane. It connects with my router using 2.4GHz (wireless N) and with my devices using 5GHz (wireless AC). When I'm connected directly to t...
Geochron
Aug 04, 2017Initiate
Hey! Yes same thing here in either fast lane mode speed is halved, so that's router to extender in either but not both 2.4 or 5 ghz and then router to device on the opposite.
What's interesting though is that simply leaving the default with fast lane off and broadcasting both frequencies from the extender I get nearly the full connection speed.
Ill be leaving my extender in the default without fast lane as it's twice as fast for me. Interested to hear if others see the same.
- CCBaxterAug 07, 2017Aspirant
Hi Geochron, thanks for the reply.
I just tried turning off fastlane and using "basic mode", but the results are basically the same. Maximum speed is about half of when connected directly to the router. Curious that it's twice as fast for you, I wonder if anyone else is getting faster connections with fastlane off.
My results:
Phone directly connected to the router - 80Mbps
Phone connected to extender with fastlane ON- 35Mbps
Phone connected to extender with fastlane OFF (Basic Mode)- 35Mbps
- exxtreme76401Aug 09, 2017AspirantNote that distance and obstructions from the extender plays a great deal into how fast the connection speed is. My Netgear ex7300 can do 1300 mb/s but realistically does more like 866 across the room. That real world speeds of ~170 MB
- CCBaxterAug 13, 2017Aspirant
Hi, thanks for your reply.
I understand that, that's why I'm performing these speed tests with the extender close to the main router, so I can have an exact reading of its maximum performance.
Same question stands since I first posted this topic: does this Fastlane mode Netgear sells as "ideal for HD Gaming and HD video streaming" bring any real benefit for real life usage, or is it just some marketing jargon to convince people they're buying some kind of wifi mesh system that won't have the usual 50% loss in speed most wifi extenders have.
