ianw314
Feb 23, 2016Aspirant
Having Trouble connecting my Powerline 500 + WiFi (XWNB5201) NETGEAR POWERLINE AV500
 Hi All,     First of all I am deaf and find great difficulty when seeking for any assistance as I'm obviously unable to use the telephone.     I bought this specific device as this was recommended by...
DarrenM
Feb 24, 2016Sr. NETGEAR Moderator
Hello ianw314
Does your powerline base share the same wall that is powering your appliances like your refrigerator or washing machine? That can cause to much noise on the powerline for it to work you would have to move the powerline adapter to a different wall. Also have you tried to test the unit in a different room to see if you can get it to work just for testing?
DarrenM
ianw314
Feb 24, 2016Aspirant
Hi Darren,
Thanks for taking the time to reply.
Theres no electrical appliances in the room and yes I've also tried the adapter in another room.
How common is it for a new Powerline to be delivered faulty?
I have the Communications Engineer coming to install a TP Link wifi Powerline next week so this may confirm if it's the Netgear Powerline that is faulty.
- DarrenMFeb 24, 2016Sr. NETGEAR ModeratorIanw314 I wouldn't say its common but it could be a faulty unit. DarrenM - ianw314Feb 24, 2016AspirantDarren as I said in my first post I bought the Powerline directly from Virgin Media, however I require a little guidance on who to contact for a refund. Would this be Virgin Media or Netgear? - DarrenMFeb 24, 2016Sr. NETGEAR ModeratorIanw314 For a refund it would be Virgin Media if you were needing a RMA on the product it would be Netgear. DarrenM
