oviedowinegirl
Mar 11, 2016Aspirant
HELP ME!!!!!!!!!
I had POS troubles yesterday, tech on my POS end had me factory reset the netgear wireless extender. BAD IDEA! I now can't get it to connect to wifi and this is how my reciepts print as well as cred...
JohnRo
Mar 11, 2016NETGEAR Employee Retired
Hello oviedowinegirl,
Welcome to the community!
If it had beed reset to factory the settings of the device will be deleted and go back to default. What is the model number of your wireless extender? You'll probably need to reconfigure it, I hope you could remember the SSID, passphrase and security type.
Thanks,
oviedowinegirl
SOrry, model number is NETGEAR WN2500RP
