shooie
Aug 30, 2015Follower
Help... oops pages do not help!!!
When I type in www.mywifiext.net I am taken to an oops page. From that page I am routed in an oops loop. How do I install my WiFi Extender
nhann
Sep 01, 2015NETGEAR Employee Retired
Which NETGEAR extender are you setting up? What router are you connecting to the extender?
Please try in your browser
mywifiext.net (without www.)
or
192.168.1.250
- fairytailchihuaSep 02, 2015Aspirant
I get the same thing on my WN2500RPv2 and neither of your suggestions worked for me
- nhannSep 09, 2015NETGEAR Employee Retired
Hi fairytailchihua,
Is this an initial installation?
Which router is connected to your extender?Please confirm that your computer is connected to "NETGEAR_EXT" (the default network name of the Extender)
Then open a web browser and try either of the addresses mentioned above.- fairytailchihuaSep 09, 2015Aspirant
No this is not initial installation and my externder works fine I just can't access my settings. I think the router is Lynksis. I live in an RV Park and the router is in the office. Before I bought the extender I could barely stay connected and now I have the ability to play games so I'm very happy. For some reason just out of the blue my settings page appeared so I'm not sure what was done differently. Sorry
- RR-JeffPNov 08, 2015Aspirant
Hi, I just purchased the WiFi Range Extender AC750 Model EX6100. I'm also getting the "oops" message. My problem is, I set up the extender and can not log into it because I don't have the passsword. I can't figure out how to change the password because I am unable to log onto the genie. Please help.
- nhannNov 09, 2015NETGEAR Employee Retired
Hi RR-JeffP,
http://support.netgear.com/product/EX6100
Please see the user manual (page 39 of 48):
http://www.downloads.netgear.com/files/GDC/EX6100/EX6100_UM_27Oct2015.pdf
and reset your EX6100 back to factory default settings.
Then go to page 9 and follow the setup procedures.
Connect to the _EXT network and open a web browser.
Go to mywifiext.net (make sure you are connected to only the _EXT network and no other internet connection such as your router)
Follow the on-screen setup.
After setup, your default credentials for mywifiext are:
user = admin
password = passwordThe password to connect to your extender's WiFi network should be the same as your router (if the box was checkmarked to make it the same as your router)
