Francesd's avatar
Francesd
Follower
Dec 16, 2015
help please :( wn1000rp wifi extender
A family member tried to set this product up but couldnt anmd i think broke it, because now when i try to factory reset it the wifi light stays amber and wont change, it wont blink or nothin..........
I hold down the reset button for 10 seconds but nothing happens to the light and it wont change from amber to green or blink.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Francesd
    The amber light indicates the wifi is at good signal. Have you tried to log into the extender by going to http://www.mywifiext.net.​ This should let you set the extender back up.
    DarrenM
