mar1a
Aug 22, 2018Aspirant
Help! Smart devices no longer get internet via Wifi Extender!
Dear Netgear Community!
My wifi extender (EX6150v2) has been working fine until recently, when it no longer gives you any internet even though it says that the smart device is connected to the exte...
Aug 22, 2018Guru - Experienced User
Is the router link LED lit? If so, what color? See page 6 here if you need an explanation on the LEDs: http://www.downloads.netgear.com/files/GDC/EX6150v2/EX6150v2_UM_EN.pdf
Also, did anything recently happen on your network around the time it began to fail? For instance, did you change routers? Did you have a power failure? ...
mar1a
Hiya! Many thanks for your reply. The LED light is yellow.
Nothing that I know of happened, but I did switch off all the internet/and all sockets when I went on holiday for two weeks at the start of July - perhaps it could be connected to that in some way?
Thanks!
- StephenBAug 22, 2018Guru - Experienced User
Do you recall if it was yellow before? If practical, you could try moving it a little closer to the router (enough to get a green color), and see if that changes anything.
- mar1aAug 22, 2018Aspirant
I suppose its actually green (same colour as the other LED lights on the extender). It has always been this same colour.
Before I went away and switched everything off it worked very well without interruption. But now sometimes it allows you to go online for some time and then after a couple of minutes you get the "not connected to the internet" signs in the browsers.
Ok. And you are never seeing this when you are connected to the router network, correct?
Have you tried "rebooting" the network? You'd turn off the extender and the router. Then turn on the extender, and wait for it to fully start up. Then turn on the extender
