dhor
Apr 10, 2020Aspirant
Help with R7900 and EX7700 wired setup
I'm having issues with my setup and wondering if anyone can help. I would like to connect the extender to the router via ethernet, but when doing this, I'm only able to wirelessly connect to the internet via the 5g network, which has worse reception than the 5g2 network for whatever reason and cuts out frequently needing hardware resets. 5g2 connects but says there is no internet connection - however, any devices connected to the router or extender via ethernet connect to 5g2 with no issue. When I disconnect the ethernet from router to extender, everything works fine (just slower speeds). Any ideas how to fix this issue so that I can connect router to extender via ethernet and still have all networks function?
Also considering another extender to reach some far away areas of the house. Is there an extender that I can add to the network to do this well, or am I really better off going with a mesh system?
What firmware is on your EX7700?
If you're having issues, I'd recommend re-installing the firmware, factory resetting, and installing using the installation wizard (not wps).
What modem is the R7900 connected to?
I'm not a fan of running multiple extenders. to many issues happen. If you're thinking you want more/better coverage, a full mesh system usually works much better in terms of performance and stability.
- dhorAspirant
Thanks for your response. EX7700 is running on V1.0.0.206 and the R7900 is on V1.0.3.18. Umm not sure on the modem, it's running via ethernet directly to the Verizon Fios box outside my home. And yeah mesh might be the next step, since this extender didn't help all that much which is a shame, I should've returned it when I first got it but the internet connection/speed has gotten worse over time.
You said the router connection is stable?
Maybe its interference. You have tried changing the router's wifi channel for 5ghz?
you can also change which 5ghz signal the extender connects to. maybe there's less issues on the higher band versus the lower 5ghz band (or vice versa)
