FPP
Mar 13, 2020Aspirant
Help with Set up
Hi All, I just purchased an older AC1900 Extender EX7000. I have tried to setup it up with no luck. I followed https://kb.netgear.com/26079/Install-EX7000-as-a-Wi-Fi-Range-Extender At step ...
Mar 13, 2020Guru - Experienced User
FPP wrote:Hi All, I just purchased an older AC1900 Extender EX7000. I have tried to setup it up with no luck.
At step one I do not see NETGEAR_EXT.
I have tried wireless, wired and 2 different computers, both of which are windows 10.
Help,
Fernando
maybe it was setup prior.
start with factory resetting it. while powered on, push and hold reset for 7-15 seconds. the lights should blink when its been held long enough.
Then follow the setup guide. I've linked to the support site that has the written guide and a video walk through that you can watch.
- FPPMar 13, 2020Aspirant
Thank you the info. I have done several factory resets. The video that was suggested shows select NETGEAR_EXT from the network connection as a step. I never see that connection. I only see my current router (and a few neighbours).
Fernando
- plemansMar 13, 2020Guru - Experienced User
what region are you in?
Are you able to access the extender if you hardwire into it for setup?
What are the led's on the front of the extender doing? color/solid/blinking/etc.
What router are you connecting to?
Firmware on the extender (if known)
Region: I live in Ontario, Canada.
Hardwire: No I do not see the router if use an Ethernet cable.
Led's: The led's appear to yellow for the top 3 and blank for the numbers
Router If you mean my router/modem, I have Bell Hub 1000. It works perfectly.
Firmware: Sorry I do not know the firware version of the extender.
Fernando
