Gerchris's avatar
Feb 09, 2023
Home wifi network for new built house
We are building a new house with LAN connections in most rooms, but i want to set up a strong home Wifi network and need advise on best path forward (we have 2 home offices). Which would be better th...
  • plemans's avatar
    Feb 09, 2023
    I would go with a mesh system.
    It makes roaming much more efficient and easier.
    They just work.
    Versus using a standard router and then access points tends to have less roaming capability/stability.
