hstokar
May 27, 2016Aspirant
How can I extend the range of an Arlo system using a WiFi range extender?
I set up the extender using SMART SETUP as extender - all green lights - yet I cannot connect to the extender with either of my computers. Both give proxy error messages when I run network troublesh...
DarrenM
May 31, 2016Sr. NETGEAR Moderator
Hello hstokar
What extender do you have? have you tried to change the security type on the extender or tried to remove security to test if you can connect. Also try to tell your devices to forget the network and try to connect again.
DarrenM
