Kittydoo
Dec 01, 2017Aspirant
How do I adjust security settings on AC1200 Range Extender to WPA?
I have a Samsung Smart TV (6 series, I MU6920) that won't connect with the extender. Saw another post that said changing the security settings on the extender to WPA may help. Any idea how to do that? Thanks!
- DarrenMSr. NETGEAR Moderator
Log into your extender by going to www.mywifiext.net then go to the wireless settings and select WPA in the security options.
DarrenM
- KittydooAspirant
Hi - I visited the site, which took me to Netgear Genie. Under the menu, I checked Settings, wireless dropped down as an option, and i ventured there. There was no option for security, so i went into ever drop down menu possibility, and security was not listed anywhere. Any other thoughts?
under security options you want click the bubble that has WPA-PSK [TKIP] + WPA2-PSK [AES] and then click apply at the top of the page.
DarrenM
