tangonovember
Jun 04, 2016Follower
How do I connect my AC 1750 Smart WiFi Router to my WN 2500 RP range extender?
I have just installed an AC 1750 Smart WiFi Router (Netgear R6400) to replace my Netgear WNDR 3400 router. The router is directly wired into my desktop. I have been able to establish wireles...
TheEther
Jun 04, 2016Guru
You can use WPS. Log into the R6400, go to ADVANCED > WPS Wizard and click the WPS button. Then go to the WN2500RP and push the physical WPS button on the side within 2 minutes.
Or you can push the factory reset button on the WN2500RP and set it up as a new extender.
