Captdana
Jun 18, 2016Follower
How do I enhance my reception? PR2000
I live on a yacht and use Marina wifi to connect to the Internet. The PR2000 has been a great added layer of security for me. Also in some marinas you need a separate password for each device, with t...
TheEther
Jun 18, 2016Guru
Get a range extender that supports Access Point (AP) mode and plug it into the Ethernet port on the PR2000. Most Netgear range extenders will work, except the WN2500RP. Be sure to verify support for AP mode by checking the manual online. You can also use a router as an Access Point.
