Motorbike's avatar
Motorbike
Follower
Mar 22, 2017
how do i reconnect my wifi extender (WN3000rpv2) to a new wireless router?
What are the steps I need to take to get my old wifi extender to connect to my new wifi wireless router?  Thanks!
Mike
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Motorbike
    You will need to factory reset the extender by holding the reset button for 10 seconds then you should be able to set up the extender again.
    DarrenM
