Dino1956
Oct 01, 2016Tutor
How Do I Set Up 2 Netgear WiFi Extenders?
I have 1 Extender set up and it has worked great for 2 years. This one is extended from my AT&T Netgear 7550 Router. I just purchased another extender. During setup, I would like to extend it from m...
Dino1956
Oct 01, 2016Tutor
The 1sr Extender is WPA2. And I have the 2nd Extender daisy chaining off the first.
Which is my only choice, after hearing your reply. There is no possibility of wiring them to router and to each other.
I wish it would at least give me the option to extend both from the Router.
But again, it reports my Router falsely having WEP security.
And If I had an option of running Ethernet cords, I would no longer need the extenders.
I would just run 2 lvery ong Ethernet cables directly from the back of my Router.
But, why is it giving me false info on my Router saying it's Security is WEP?
That to me makes no sense what so ever. Sounds like a glitch in the software.
Thanks for your suggestions. I do appreciate it.
P.S. I thought I saw somewhere in the community a post about someone running 2 extenders, extending both from the Router with success.
That's really how I planned on setting it up originally.
TheEther
Oct 01, 2016Guru
You misunderstood me. You should not daisy chain extenders. But in order for extend both from the router, the extenders must broadcast a different SSID from the main router. Are you doing that?
- Dino1956Oct 02, 2016Tutor
Ok. Yes, again, I had no other choice since it's saying my router has WEP security, which is NOT the case. My router is usingWPA2 for security.
How do I accomplish that?
How do I make the Router Broadcast a different SSID for one then the other?
The setup is so straight forward.
I see no advanced set up using the browser mywifiext.
Is that something I can do on the router?
Oh. The SSID is the name of the device?
Yes, they all have different names.
Router: DCS
Extender1: DCS_EXT2
Extender2: DCS_EXT3
- TheEtherOct 02, 2016Guru
Ok, that works. It's strange, then, that extender2 is trying to use WEP security. Perhaps you can try resetting extender2 to factory settings.
Been there, Done That!
What is strange is that it is reporting that my Router's Security setting is WEP, when it definitely is not. So I can't connect it to the router.
Extender 1 definitely extended from the router and IT reported the true security setting on my router when I set it up, which is WPA2 but since I put another Extender in the mix it won't allow me to extend it from the router.
