lalamoe's avatar
lalamoe
How to change IP Address back?
Hello, you can probably tell I am a newbie here and my knowledge with routers and whatnot is very small :( Which would explain why I made this big mistake and now I want to reverse what I did. A few months ago (not sure exactly when) I changed my IP Address with a youtube video as a guide. I have a Netgear Wireless N-150 Router, along with a Scientific Atlanta modem. According to my mom, Comcast assigned us an IP Address, and I had changed it before they told me it wasn't right to change an IP Address a company assigned me and that I wasn't supposed to. Now, I don't remember what was the website I used to change it and I can't find the video D: Ever since that change, my laptop has had problems too. The internet crashes every few hours and I have to disconnect and re-connect the router and wait a minute or two to get it back again, and everytime I click on a site, it redirects me to another. Please help, I want to get everything back the way it was but I don't know how :confused:
  • 1. turn off the cable modem and unplug ethernet cable
    2. wait for few min (5min)
    3. turn on the cable modem only and do NOT plug any ethernet cable
    4. wait until all the light up on cable modem
    5. ONLY after all the light is up. hook up a router behind the cable modem
    6. you should able to get public IP from the ISP and it will show up in the router status when you login the router.
    post specific model of the unit
    To first quote, reset the the router as well. see router reset on my sig below and do that first and follow the 1~5 instructions
  • Thankyou for helping me out!
    I clicked on your "Router Reset", and I went to the No.4 instructions, but I don't know If I either have to follow Step 1 and then Step 5, or I can only do one of them?
    Also, I can't find the box the modem came in but I see a couple of numbers and characters on the side of the modem:
    S/N 222344895
    MAC 0023BE8ECFEA
    DPC2100R2
    CABLE MODEM
    Rating: 12V 1A
    P/N: 4012460
    HW Rev.: 2.1
    I don't know if this will help, but it's what I see.
  • Yes that's the modem!
    And surprizingly I comprehend everything, despite my lack of knowledge on computers :P Except for instruction number 5, where I have to hook my router behind the modem. Which cable do I use to hook it to the modem? The only cable that connects them together right now is the ethernet cable.
  • cable between cable modem to internet port of router..
    can be that difficult about it
  • I need to change the 3rd number ex: 192.168.1.. the "1" needs to be a 3,4,5 or something other than the "1". No where tells how.
