shelquis's avatar
shelquis
How to Connect to 5GHz Channel?
Hi, I've got a WNDR3700v2 that's an access point for an XP and a Win7. On the Win7 machine, I can only connect to the 2.4GHz channel.
When I click on the signal bars in the task panel and bring up the Network and Sharing Center, it shows I'm connected to the 2.4GHz channel. If I click on View your active networks, Connect or disconnect, it shows I'm connected to the 2.4GHZ channel, and it shows some neighbor's networks, but it doesn't even list my 5GHz channel.
When I click on Manage Wireless Networks in the left side menu, it says Windows tries to connect to these networks in the order listed, and it lists my 5GHz channel first, and the 2.4GHz channel is listed second, so that looks right, but for some reason it's not connecting to the 5GHz channel.
Does anyone have any ideas how I can make the 5GHz channel show up so I can connect to it?
  • jmizoguchi wrote:
    pc must support dual band (dual band wifi adapter )
    Thanks for the reply June. Here's my computer adapter info from msinfo. It doesn't specifically say "dual band", but since it mentions b, g and n, I assumed it was. What's your opinion?
    Name [00000011] Dell Wireless 1502 802.11b/g/n
    Adapter Type Ethernet 802.3
    Product Type Dell Wireless 1502 802.11b/g/n
    Installed Yes
    PNP Device ID PCI\VEN_168C&DEV_002B&SUBSYS_02041028&REV_01\001517FFFF24141200
    Last Reset 2/10/2012 3:41 PM
    Index 11
    Service Name athr
    IP Address 192.168.1.7, fe80::18aa:5efc:58f8:f334
    IP Subnet 255.255.255.0, 64
    Default IP Gateway 192.168.1.1
    DHCP Enabled Yes
    DHCP Server 192.168.1.1
    DHCP Lease Expires 3/13/2012 11:58 PM
    DHCP Lease Obtained 2/12/2012 10:58 PM
    MAC Address E4:D5:3D:88:2F:2E
    Memory Address 0xFE400000-0xFE4FFFFF
    IRQ Channel IRQ 17
    Driver c:\windows\system32\drivers\athrx.sys (9.1.0.328, 2.26 MB (2,374,656 bytes), 12/5/2011 3:57 PM)
  • jmizoguchi wrote:
    Only supports 2.4Ghz
    Thanks June. For my education, what identified that it supports 2.4GHz only?
  • I have a 3400 router and have the same issue, the blue light never blinks. Looking and my lan card on my laptop, it does support 5GHz:
    Realtek RTL8188CE Wireless LAN 802.11n PCI-E NIC
    I tried enabling 11n AdHoc but that didn't do it.
    Any suggestions?
    Any suggestions?
    ad-hoc are not going do any for connecting to wireless router . ad-hoc is for other wifi device to connect your laptop directly
    if you are wireless do NOT support 5Ghz than not use of trying. replace the PCI-C card with dual band support card or buy USB wifi adapter instead
  • How can I tell if my Network Adapter accepts dual band. I am running a Atheros AR9285 Wireless Network Adapter. It was pre-loaded onto my laptop.
