Dec 22, 2016Initiate
How to get access to 192.168.1.1?
 If you enter 192.168.l.l to http://192.168.1.1  modem router administrator password & login IP addresses. 192.168.1.1 IP addresses is the address of your ADSL modem administration panel. All the manu...
DarrenM
Dec 28, 2016Sr. NETGEAR Moderator
This should log you into your router I am not really sure what issue you are having can you explain?
DarrenM
