Dec 22, 2016Initiate
How to get access to 192.168.1.1?
 If you enter 192.168.l.l to http://192.168.1.1  modem router administrator password & login IP addresses. 192.168.1.1 IP addresses is the address of your ADSL modem administration panel. All the manu...
andrewkhinkle
Sep 04, 2017Tutor
I have mentioned some simple steps to access 192.168.1.1 below, you can try these steps.
- Hit enter button and 192.168.l.l admin page loads in few seconds.
- If the page didn’t load, then your router’s login ip address is differect. (Find Router IP Address)
- Provide Username and Password details of your Wifi router.
- Generally, you can Find Default Router Username and Password details provided backside of router or router package box.
- Once you login, WIFI admin panel appears where you can make changes of router configuration.
- If in case you changed the default username/password details, follow the below instructions which will guide you to recover them quickly.
More Information : 192.168.1.1 Admin login – 192.168.l.l Reset Router Username & Password
