Dec 22, 2016Initiate
How to get access to 192.168.1.1?
If you enter 192.168.l.l to http://192.168.1.1 modem router administrator password & login IP addresses. 192.168.1.1 IP addresses is the address of your ADSL modem administration panel. All the manu...
andrewkhinkle
Sep 30, 2018Tutor
Follow these Simple Steps for 192.168.1.1 Login through the Gateway which gives access to Configure and Change Settings of your WiFi Router.
- Enter Official Site 192.168.1.1 or http://192.168.1.1 in any of your Browser (IE, Firefox, Google Chrome, Safari).
- If the Login Page is Not Opening, then 19216811 is not your Router’s Default IP Address. Refer this Article to Find Default Router IP Address.
- Once you Found the Correct IP Address, Insert the same into your Web Browser Address Bar.
- You’ll be Forwarded to Login Panel which asks for Username and Password to Sign In. Check out Default Username and Password.
- Follow this Guide if you Forgot Username and Password of your Router.
- Put down the Credentials and you’re in. Refer to FAQ’s, If you have any Issues.
- leoliangJun 23, 2022Aspirant
192.168.1.1 is the default login path of many routers, some of which are 192.168.0.1. The login paths of different models are different. For example, I have tp link archer ax90 and the default login path is 192.168.1.1. If you use netgear router maybe the same or maybe different.
