alcat's avatar
alcat
Luminary
Nov 19, 2017
how to list devices attaching via Extender
Hello - I have the Nighthawk x6 r8000 router and Nighthawk x6s ex8000 Extender. All is working as expected and the deadspot in our detached garage is no longer a deadspot. Super strong WiFi signal !!!
However I have a couple "How to" questions.
1 - Is it possible to see a list of devices attaching to the router via the extender? The devices going thru the extender show up as attached directly to the router in Genie and the Web Admin Interface. I know they must be going thru the extender because when I turn off the extender the connection goes from All bars to one bar and connectivity is horrible.
2 - Why does the extender show only one of the two 5GHz bands as available? I can see the 2.4GHz band and one 5GHz band only.
I love this extender but not the admin interface.
thanks
al
  • The second 5ghz band is used as a dedicated band connected to the router.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
    • alcat's avatar
      alcat
      Luminary
      thank you that makes sense to me.
      Plus I found that I can see the attached devices in Genie by double clicking the ex8000 device in the device map/
      al
