parker1031's avatar
parker1031
Follower
Jan 05, 2018
HOW TO RECONNECT NETGEAR WIFI EXTENDER
i HAD CHANGED THE PASSWORD ON MY ORIGINAL WIFI ROUTER, I TRIED USING THE NEW PASSWORD ON THE WIFI EXTENDER AND DIDN'T WORK. MY BROTHER IN LAW DECIDED TO RESTORE FACTORY SETTINGS AND NOW IT WON'T CONNECT TO THE ROUTER AND I CANNOT LOGIN INTO THE EXTENDER WHEN i FIND IT'S NAME ON WIFI SETTINGS. WHAT CAN I DO, IF ANYTHING?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Try to reset the extender again by holding the reset button for 10 + seconds and try the setup process again.
    DarrenM
