Yozen
Dec 21, 2018Follower
How to reinstall ExtenderEX 6100
I changed my provider to Spectrum but I cannot get the EX6100 to work. I followed the instructions on line carefully with respect to setting up the extender with the WPS button on the MySpectrum WiF...
Dec 21, 2018Guru - Experienced User
Try resetting the extender, and don't press WPS - do you see a wifi network called NETGEAR_EXT?
If you do, join that, and then browse to www.mywifiext.net.
