Mehrdad
Jul 13, 2017Aspirant
How to set WNDR3300 as repeater with R6400 as the base?
Can't be done.
- MehrdadAspirant
Which router can I use with R6400?
If you want to do it wirelessly, then you need a range extender. It's strongly recommended, however, that you use a wired connection to an Access Point. Most, but not all, range extenders can be used as Access Points.
